Sheet Pile Shear Strength of Soils
Hello All,
I am developing soil parameters for a sheet pile, and one needed parameter is shear strength.
Is there a way to determine the shear strength of a soil from the internal friction angle and moist density? If not, how should we estimate the shear strength given SPT N-value, or is there another way outside of running an actual shear strength test.
I've looked through many textbooks and articles online but am having a tough time finding anything that helps. We have a chart at work that give parameters of certain soils/rocks. For example, the given ultimate shear strength of limestone, depending on SPT N-value, is between 4 and 15 ksf. I need the same parameter for sand and clay.
I've read that the shear strength of a clay is the unconfined compressive strength divided by 2, qu/2 = Tf.
I am hoping to find some empirical data or a formula.
Thoughts?
Thank you for the help!
Thoughts?
RE: Sheet Pile Shear Strength of Soils
However, I have copied from an older version and perhaps between the two you can get what you want.
Figure 3 on page87 may help.
http://web.mst.edu/~rogersda/umrcourses/ge441/dm7_...
Is there a way to calculate the shear strength of a soil without knowing the effective stress being put on it? From what I've found shear strength is as follows:
τf = σ*tan(Φ)
Internal friction angle (Φ) is found from SPT N-values. What I don't understand is that somehow in previous reports that our company has issued we have given the shear strength of sand to be 390 psf at a depth of 4 feet. But this isn't coming from the above equation because the shear strength in the same boring at a depth of 30 feet is given as 400 psf, thus neither the depth nor the effective stress play a role. GWT = 2.0 ft
Is there a correlation between density and shear strength? Or passive and active pressures and shear strength? Has you can tell I am grabbing at straws here.
Thank you again for the help!!!
In your case, I'd see if you can find a mentor that is more experienced, since you may be missing something that could be important. Using blow count alone is rather crude and sometimes all we have, but it is a very approximate indicator of soil properties. Get out with a drill crew and you may see how the number can be affected by many things.
