ASME Section VIII Div I: Repair - Rewelding of A Coupon Back onto A Pressure Vessel
I am seeking guidance for acceptable repair to a pressure vessel. In this instance, a fabrication shop punched a hole in the wrong spot of a pigging barrel (see attached picture). After notifying 3rd party inspection, they took the plug (same material grade, composition and thickness) beveled it back and shot 100% x-ray on the repair spot. Additionally they did a 14 hour hydro test at 1800 PSI on the vessel (1.5 x design).
I'm coming up short for answers when searching ASME Section III Div I. Is this an acceptable repair? If not, what, if anything, is considered acceptable?
Greatly appreciated.
RE: ASME Section VIII Div I: Repair - Rewelding of A Coupon Back onto A Pressure Vessel
Unfortunately the repair in your picture looks not good at all, as the owner I would not be happy.
Mike
SnTMan: That was also the only relevant section I could find as well. I agree, it looks like poor workmanship.
Thank you both for your replies!
-Craig
