Twist a solid body in NX 8.5
Hello, can I twist a solid body in NX 8.5 ?
Actually, first I had a sketch where I swept it along a helix. After that I used the Draft option but unfortunately the body is no more twisted as it was(it's an airfoil).
Can I know twist it again ??
RE: Twist a solid body in NX 8.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
The airfoil now has a certain twist.
Why when I want to increase the Offset value (which is minimum now is 0.06 mm), the twist will not show as original ?
For example, I want the Offset to be +1.5 mm with same twist.
Yes, in certain cases everything works for you as you would expect that it would. For example if you were to offset a Spherical/Cylindrical/Toroidal/Planar surface/face then the results would another Spherical/Cylindrical/Toroidal/Planar surface/face. Unfortunately that's NOT the case when you offset a so-called freeform surface/face. For example, the offset of a NURB surface is NOT another NURB surface. It's something else, but it's no longer a NURB.
This is also true in the 2D world. For example, the offset of a Circle is another Circle, but the offset of an Ellipse is NOT an Ellipse. Now you might get away with small offsets and still get a result that is close enough, but eventually you'll reach a point where things fall apart. Now I don't mean that an operation will fail, just that it gets to the point where the approximations are no longer "good enough". I suspect that that's what's happening in this case.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
This is indeed strange but it does not cover the fact that NONE of the two sketches are even close to be fully constrained, they are both fully free to move X and Y and rotate.
- Go back and make the sketches fully constrained.
In the attached image i have added a datum CSYS such that i have something to constrain against... Then the offset is 2 mm.
Tomas
Insert ---> Offset/Scale ---> Thicken.
But at the same time, could you please Mr. Toost attach here the NX file which you modified.
Thank you.
Again I looked at it and the rotation is probably due to that the expression : "Airfoil_Thickness_Offset"
is used in both sketches as :
Chord_Length=37.7-2*Airfoil_Thickness_Offset
This makes the sketch move.
Then still both sketches are free to move XY + rotation. ( you can try open one of the sketches and drag something , it will move.)
Tomas
