Pig Trap Nozzle reinforcement
Hi All,
we have a Pig trap to be designed and procured, size is 24" x 18", wall thickness of 11.31 mm.
Clinet asks for reinforcement of nozzles. Can you guys help me with , which codes to be followed..
The pig trap to be designed as per ASME B31.4..
RE: Pig Trap Nozzle reinforcement
Calculate a torus with an area that matches the finished diameter of the nozz hole, and cut a repad with those dimensions from your shell material. Don't forget the 'weep hole' so that the installed repad can be air tested.
See section 404.3 or just use "integrally re-inforforced branch connection fittings" AKA weldolets.
