Dimension parallel to an angled edge
In Drafting, how could I add a dimension between two points parallel to an angled edge? (i.e. the dimension line should be parallel to the angled edge)
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
RE: Dimension parallel to an angled edge
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
If so, use the 'Linear' dimension function and set the Method to 'Point-to-Point' and when you do there will be an additional option offered to 'Use Measurement Direction'. Just toggle it ON and then you'll be given the option to explicitly select the 'vector' that you wish the measurement to be taken relative to, and by definition, the text will be created parallel to that vector as well.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Rapid Dimensions have most of the options/methods in the Dimension dropdown box. I hope in the next releases NX will centralize the cluttered options/methods and clean and delete the duplicates to avoid this kind of situations.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
