SMYS question
SMYS question
In regards to steel pipelines, what is the yield strength point referred to as being the SMYS of the pipe when looking at a stress-strain curve for steel? Is it the yield point on the stress-strain curve that accompanies the beginning of plastic strain? But I've also read about the difference (for materials) between "Upper Yield Strength" (where the sudden drop in stress happens...the point that accompanies the beginning of plastic strain) vs the "Lower Yield Strength" (the lower being the "plateau" yield strength after the initial yielding occurs). I was reading in the Lindeberg PE reference manual that LOWER yield strength is commonly reported as the yield strength.
So my question for steel pipelines: is SMYS (1) the point that accompanies the beginning of plastic strain, OR (2) the LOWER "plateau" yield strength?
RE: SMYS question
RE: SMYS question
RE: SMYS question
This defines two ways of testing for this.
For pipes > L 625 / X90 then it is the 0.2% offset method or Rp0.2
For all others it is the Rt0.5, i.e. the stress at which strain of 0.5% occurs.
See this for an explanation of what that means... http://www.tiniusolsen.com/pdf/Pamphlet4.pdf
As TGS4 says - look in the spec for your particular definition for your material / specification.
