Is this a Fusible vs non-fusible disconnect switch ?
Hi all ,
I've 2 samples of disconnect switches , Square D and G.E.
I just want to know are they fusible vs non-fusible ? because I already graduated and I never seen them before
and if you have a picture or diagram for fusible vs non-fusible showing the difference between them , I will be really appreciated .
RE: Is this a Fusible vs non-fusible disconnect switch ?
Sorry , I mean fusible "or" non-fusible
Non-fusible. There are no fuse holders.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Fusible would be in a longer box to accommodate the fuse clips as well.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Thanks guys :)
