Fracture Mechanics
Fracture Mechanics
Fracture Mechanics
Does anyone have any good liks to sites that deal with flaws / cracks in pressure vessels subject to cyclic pressure loading?  Anything that relates to Paris equation and the likes?
Scotland6
RE: Fracture Mechanics
Dr. Ted Anderson of the ASME PROFESSIONAL DEVELOPMENT ASME/API 579
(WRC Bulletin 441)
http://www.srt-boulder.com/biographies.htm
Fracture Mechanices Fundametals & Applications
Author - T.L. Anderson
CRC Press
Catalog number 4260 BA
December 1994, 704 pp.
ISBN:  0-8493-4260-0
Leonard
http://www.forengineers.org/pvrc/bulletins/471.htm
Development of Stress Intensity Factor Solutions for Surface and Embedded Cracks in API 579
WRC Bulletin 471 -- MAY 2002
Ted L. Anderson
Gregory Thorwald
Daniel J. Revelle
David A. Osage
Jeremy L. Janelle
Matthew E. Fuhry
The Bulletin presents a comprehensive numerical study in which a large number of Mode I stress intensity factor ( ) solutions for cracks in plates and shells were generated for inclusion in the American Petroleum Institute (API) Recommended Practice on Fitness for Service (RP 579).  A series of 2D and 3D finite element analyses were performed on plates, cylinders, and spheres containing surface cracks and buried cracks.  A wide range of flaw aspect ratios at radius/thickness ratios were considered. The results of these analyses are tabulated.
The Bulletin also describes a weight function methodology in which  solutions for arbitrary through-wall stress distributions can be derived for surface cracks in plates and shells.  The weight function for a given geometry and crack size is derived from reference solutions for uniform and linear crack-face pressure.  The necessary reference  solutions for surface cracks in plates, cylinders and spheres are provided.
ISSN: 0043-2326
ISBN: 1-58145-478-3
 Library of Congress Catalog Card Number: 85-647116
Number of Pages: 79
The price of WRC Bulletin 471 – MAY 2002 is $US 125.00 per copy plus $US 5.00 for U. S. and Canada for postage and handling and $US 10.00 for other locations for postage and handling.
Use the website www.forengineers.org/pvrc to purchase this bulletin, or correspond with payment (check, VISA or MASTERCARD) to the Welding Research Council, 3 Park Avenue, 27th Floor, New York, NY 10016-5902.  Phone 212-591-7956; Fax 212-591-7183; e-mail wrc@forengineers.org.
