Double joint weld definition
Sorry, my question might be basic knowledge. I try to find searching by google..but still getting any confuse
My question is about double joint welding , which commonly used in offshore pipeline installation.
1.What the definition of double joint, can someone to give brief explanation?
2. Is the double joint weld means the weld is only can be done by done internal weld and external weld of the pipe or also can be done by external weld over external weld?
3.Is this joint can eliminate the requirement of field joint coating? Why?
Hope Your answer can enlighten me..
Thank you
Zachari Alamsyah
Thank you
Zachari Alamsyah
RE: Double joint weld definition
Have a look at this link and see figure 6.7
http://www.g-w.com/pdf/sampchap/9781590708668_ch06...
ZA
