Text disappearing in 2d
Hi
I wondered if anyone can help. Just upgraded my workstation and I've noticed my text keeps disappearing every time I stop panning or zooming.
When I pan or zoom, all the dims and text can be seen very clearly, as soon as I stop they all disappear.
I'm using Catia V5r20
AMD FirePro W5100 (fireGL V)
I'm assuming it's a graphic card issue but can't find anyone else reporting this problem. I've updated to the latest driver but have had no luck.
Anyone help?
RE: Text disappearing in 2d
Thanks for the quick response.
I'm not sure exactly what files to delete there, can you help me? I've had a look in these forums but cannot find anything, guess the title is not as obvious as I need it to be.
I can't see anything that looks like my problem, maybe there is but I can't find it.
All these issues are around the tool boxes and specific user settings. That I understand, however, this is a graphic glitch of sorts.
I bow to your superior knowledge on this matter though and will try to find a way to delete CATSettings.
OK, I managed to delet catsettings and opened a drawing, again, I cannot read the annotation or dimensions unless I'm panning. I'm convinced this is a graphic driver issue.
Sounds like a graphics card problem to me.
But something else to try, as I suspect it might be the font: Try changing the font on some of the annotations, and see if that makes a difference. Check the properties and see if there's something there (Bold, Italic, etc) that might be causing the problem.
Also, try changing the STANDARD with File + Page Setup.
If you haven't already checked this, go to TOOLS + OPTIONS and GENERAL + DISPLAY and reset the PERFOMANCE options by using the bottom-left icon and choosing RESET THIS TABPAGE.
