Strainer screens- Open Area ratio (OAR) and differential pressure relation
Can anybody provide guidance on how to connect OAR to differential pressure across metal screens, using a calculation.. I intend to form a transfer function or show a distinct effect of the OAR on to the dP.
thanks in anticipation...
RE: Strainer screens- Open Area ratio (OAR) and differential pressure relation
The main problem is that any relationship only works on a totally clean filter / screen. Normally you aim for a ratio of 1.5 to 2 and a clean DP of 1-2 psi. Dirty DP can be anything normally up to 15psi or more depending on the strength of the filter element.
I'm sure there is a function or calculation somewhere out there, but can't really see what the purpose is??
Perforated screens with non-streamlined holes behave similar to sharp edged orifices, with similar unrecoverable losses as a function of area ratios. ASME Supplement on Instruments and Apparatus 19.5 shows discharge coefficients and unrecoverable losses for sharp edged orifices of all relevant area ratios.
Have a query wrt Wedgewire element dP calculations.
The calcs mention Screen K factor.
Does any one have any information to share wrt to the K factor.? Where does this factor originate from? Can you forward such document to me.?
Thanks for patiently responding to my queries...
have one more..
What is the International Standard for Shock & Vibration test of the Metallic wedge wire type filter element, which can be used to check the micron size or welding integrity...
thanks...
