Composite Profile on Revolved Surface
RE: Composite Profile on Revolved Surface
It comes down to what number you want to have control the orientation vs. the location. (In both proposals the size is controlled by the tighter .028.)
Thinking about location -- Proposal 1 locates the part around datum B within 0.1, while Proposal 2 also locates it within 0.1 (although only at point B).
Thinking about orientation -- Proposal 1 controls it within .028, while Proposal 2 does not; in fact the orientation is somewhat up for grabs in Proposal 2 because the position tolerance doesn't carry down onto the curve.
So my initial thinking is to go with Proposal 1. (An aside: to designate a tolerance between points A and B, you don't need the "PT" but just the letter. Also, in Proposal 2 you don't need the word "boundary" under the profile callout because profile is always a boundary idea.)
John-Paul Belanger
Geometric Learning Systems
Thanks. Unless I hear (or see) otherwise, Proposal 1 is on the print.
I was familiar with the point about "PT". Is "boundary" being dropped for 2009?
No -- boundary was only a word to be used with the position symbol. Profile tolerances by definition are always a boundary thing, not an axial thing.
John-Paul Belanger
