next page in drafting
Create or use grip to automaticly go to next page in drafting without using either pull down or selecting it in part navigator... I have seen one at another location but can not find the way they did it and I am no longer at that location
Cj Silver
Tooling Engineer BAE Systems
Working to remember all I forgotten
RE: next page in drafting
Below is a journal that should switch to the next drawing sheet (by sheet number).
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Module Module1 Dim theSession As Session = Session.GetSession() Dim theUfSession As UF.UFSession = UF.UFSession.GetUFSession Sub Main() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim currentApplication As Integer theUfSession.UF.AskApplicationModule(currentApplication) If currentApplication <> UF.UFConstants.UF_APP_DRAFTING Then lw.WriteLine("must be in the drafting application") Return End If Const undoMarkName As String = "next drawing page" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim drawingDic As New Dictionary(Of Integer, Drawings.DrawingSheet) For Each dwgSheet As Drawings.DrawingSheet In workPart.DrawingSheets drawingDic.Add(SheetNumber(dwgSheet), dwgSheet) Next Dim totalSheets As Integer = workPart.DrawingSheets.ToArray.Length 'lw.WriteLine("number of drawing sheets: " & totalSheets.ToString) Dim curSheetNumber As Integer = SheetNumber(workPart.DrawingSheets.CurrentDrawingSheet) 'lw.WriteLine("current sheet: " & curSheetNumber.ToString) 'For Each kvp As KeyValuePair(Of Integer, Drawings.DrawingSheet) In drawingDic ' lw.WriteLine("sheet number: " & kvp.Key.ToString & " name: " & kvp.Value.Name) 'Next Dim newSheetNum As Integer = curSheetNumber + 1 If newSheetNum > totalSheets Then newSheetNum = 1 End If Dim newSheet As Drawings.DrawingSheet If drawingDic.TryGetValue(newSheetNum, newSheet) Then newSheet.Open() Else 'sheet not found lw.WriteLine("error: sheet not found") End If lw.Close() End Sub Function SheetNumber(ByVal theSheet As Drawings.DrawingSheet) As Integer Dim sheetNum As Integer Dim theSheetBuilder As Drawings.DrawingSheetBuilder = theSession.Parts.Work.DrawingSheets.DrawingSheetBuilder(theSheet) sheetNum = theSheetBuilder.Number theSheetBuilder.Destroy() Return sheetNum End Function End Modulewww.nxjournaling.com
Cj Silver
In Nx goto tools - journal - play (or ALT+F8)browse to the .vb file and run. You can make a shortcut for this by customising a toolbar.
Best regards,
Michaël.
NX7.5.4.4 (NX8.5.3) + TC Unified 8.3
Win 7 64 bit
Cj Silver
