ASME B16.34 / Body Minimum Wall Thickness
at B16.34 / 6.1.2 Inside diameter,
Any one can explain me the inside diameter 'd' of safety relief valve, and 'basic inside diameter'?
See Attachments.
Thank you.
RE: ASME B16.34 / Body Minimum Wall Thickness
I work with valves in exotic alloys at alloy-valves.com. This is me on Twitter and LinkedIn. Let's connect!
