VBA Download Folder from Google Drive
I need to loop through and collect properties from folders and files on Google Drive. I have a macro that is working on folders/files on my local, so i thought it would be best to run the macro, temporarily download the file structure from Google Drive, then delete the temporary folder at the end of the macro.
I was wondering if there is a way to download a folder from Google Drive, using VBA. I found a bit of code that works for downloading a file...but I need the entire structure and I am not sure how to modify it for a folder. Any help would be greatly appreciated:)
Sub DownloadPDF()
Dim FileNum As Long
Dim FileData() As Byte
Dim MyFile As String
Dim WHTTP As Object
On Error Resume Next
Set WHTTP = CreateObject("WinHTTP.WinHTTPrequest.5")
If Err.Number <> 0 Then
Set WHTTP = CreateObject("WinHTTP.WinHTTPrequest.5.1")
End If
On Error GoTo 0
MyFile = "https://docs.google.com/uc?export=download&id=IndividualFileIDHere"
WHTTP.Open "GET", MyFile, False
WHTTP.send
FileData = WHTTP.ResponseBody
Set WHTTP = Nothing
If Dir("C:\MyDownloads", vbDirectory) = Empty Then MkDir "C:\MyDownloads"
FileNum = FreeFile
Open "C:\MyDownloads\binder.pdf" For Binary As #FileNum
Put #FileNum, 1, FileData
Close #FileNum
MsgBox "Open the folder [ C:\MyDownloads ] for the downloaded file..."
End Sub
(Source1, Source2)
Sub DownloadPDF()
Dim FileNum As Long
Dim WHTTP As Object
End If
On Error GoTo 0
WHTTP.send
Set WHTTP = Nothing
FileNum = FreeFile
Close #FileNum
End Sub
(Source1, Source2)
RE: VBA Download Folder from Google Drive
