Repeat of command
Repeat of command
How do I setup the line draw or other commands to auto repeat without having to re-click on the icon?
Thank you
Jay
Thank you
Jay
RE: Repeat of command
Also, if you added other geometry and want to go back to Line, right click and choose "Recent Input"
From the Help file:
Use the Repeat command to repeat a command. Use Repeat only with commands performed at the command window, not with commands that use a dialog box.
To repeat commands:
Type Repeat at the command prompt.
Type the command to repeat.
The command repeats, prompting you as necessary.
Press Esc to stop repeating the command.
Jay
Options
User Preferences
Mouse Options
Selected Entities
Repeats Last Command
Unselected Entities
But, the Right Click Menu is no longer available.
They were already set up. The problem was that I was using the escape key to terminate the line. I should have been using the right mouse key to terminate the line. Then the left mouse key will repeat the line draw.
Jay
Regards, Diego
