CATIA macro adds bodies (name_1) to new body (new_name_1)
Hi!
i would like to program a macro that will select:
-all Bodies named "name_1" and add them to new body with name "new group 1"
-all Bodies named "name_2" and add them to new body with name "new group 2"
-all Bodies named "name_3" and add them to new body with name "new group 3".
i successfully wrote this code on my CATIA R20, and works OK. It adds all bodies in new body. But then i tried to run a macro on CATIA R19 and R24, but it doesnt work! In R19/R24 it doesn't add all bodies named "name_1" but it adds only one body in new body! please anyone could tell me what could be the problem? see code below.. (only for one name_1)
I appreciate any response, thank you in advance
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Set objSel = partDocument1.Selection
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Set shapeFactory1 = part1.ShapeFactory
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
objSel.Clear
'******************name_1*********************
objSel.Search ("Name=name_1,all")
objcount = objSel.Count
Set body1 = bodies1.Add()
body1.Name = "new_name_1"
Set body1 = bodies1.Item("new_name_1")
part1.InWorkObject = body1
For i = 1 To objcount
Set body11 = bodies1.Item("name_1")
Set add1 = shapeFactory1.AddNewAdd(body11)
Next
objSel.Clear
End Sub
Sub CATMain()
Dim part1 As Part
Dim body1 As Body
objSel.Clear
Next
objSel.Clear
End Sub
RE: CATIA macro adds bodies (name_1) to new body (new_name_1)
In CATSCript, (only for name_1), hope you'll get the idea.
CODE --> CATScript
Language="VBSCRIPT" Sub CATMain() Dim partDocument1 As Document Set partDocument1 = CATIA.ActiveDocument Dim part1 As Part Set part1 = partDocument1.Part Dim bodies1 As Bodies Set bodies1 = part1.Bodies Dim body1 As Body Set body1 = bodies1.Add() body1.Name = "new_name_1" Set body1 = bodies1.Item("new_name_1") part1.InWorkObject = body1 part1.Update Dim selection1 As Selection Set selection1 = partDocument1.Selection selection1.Search "Name=*name_1'.'*,all" n = selection1.Count Dim shapeFactory1 As Factory Set shapeFactory1 = part1.ShapeFactory Dim i As Integer For i = 2 To n+1 Dim body2 As Body Set body2 = bodies1.Item(i) Dim assemble1 As Assemble Set assemble1 = shapeFactory1.AddNewAssemble(body2) Next part1.UpdateObject assemble1 Part1.Update End SubRegards
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Now I have no idea how to write the previous code for CATIA wich is running in NON HYBRID DESIGN ENVIRONMENT.
any suggestions?
thank you in advance,
Jon
This is one of the reasons why most companies are using such kind of options. I never tried to create a macro with other option.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
