Hole milling with Plane spatial
Hello everyone
I´m trying to create a slot starting with the operation "hole milling" in NX 8.5
I´m using a deckel maho dmu60 five axis.
Since the slot is in a cylindrical face, i need to rotate the table and normally for
this kind of operation we use plane spatial, but when generate the codes, my
postprocessor shows the program in m128 only for hole milling,
for cavity milling and drilling shows plane spatial.
Does anyone knows if is posible to have the plane spatial mode using holemilling.
