HOLES STANDARD
HOLES STANDARD
trying to create holes standard for rivets but can find nothing about that over the Internet.
created a folder in catia program files and copied standard from counterbored holes folder.
any ideas on how can this be edited?
std:node name="Metric-cap-screw" xmlns:std="http://www.dsweb.com/std">
<std:node name="Units">
<std:node name="Angle">
<std:strval name="angle">deg</std:strval>
</std:node>
<std:node name="Diameter">
<std:strval name="Diameter">mm</std:strval>
</std:node>
</std:node>
<std:typedef name="CounterBoredHoleValues">
<std:strval name="Name">MS20426AD3</std:strval>
<std:floatval name="MainDiameter">2.5</std:floatval>
<std:floatval name="CounterSunkDiameter">4.65</std:floatval>
<std:floatval name="CountersunkAgle">100</std:floatval>
</std:typedef>
</std:node>
</std:node>
</std:node>
</std:typedef>
RE: HOLES STANDARD
i want to define angle and diameter. when i save standard and create a hole using this standard
catia is still locked on depth and angle mode however definition in standard is angle and diameter.
RE: HOLES STANDARD
Derek
Win 7
23SP5/24SP3, 3DVIA Composer 2015
RE: HOLES STANDARD
