Determining the Welding Profile specified on WPS for Pipeline
Dear Welding and piping expert.
it is whom responsibility to determine the type of pipe/piping welding profile " Root depth, Spacing , Bevel angle and shape Single or double grooving , V or J type ?
On what basis these parameters " Type of profile , dimensions along with Welding electrode type [ root , hot , filling and cap ] " are selected ?
is there any engineering software to select or design the welding joint for pipe/piping ?
Tarek
RE: Determining the Welding Profile specified on WPS for Pipeline
Please don't double post.
What code are you building to?
usually the engineer designing it.
parameters, voltage/amperage/dimensions/root depth, fill and cap can be taken from ASME IX 2013.
do you already have supporting PQR's or what stage are you at with that?
nm, AWS forum. - disregard my suggestion of use for ASME IX.
I suggest referring to AWS D10 standards. AWS D10.X standards, there are several recommended practices that recommend the parameters based on base metal and welding process. Go to www.aws.org and do a search for D10. You should get several hits with a synopsis of what each RP addresses, i.e., aluminum pipe, carbon steel pipe, austenitic stainless steel pipe, etc.
Best regards - Al
