plastic line bending machine
Where can I find a machine (CNC?) that can will allow me to bend flat plastic parts (ABS, acrylic etc.) in high precision?
I will be creating a v-groove in one side to assist in making a sharp corner and will be applying glue to the inside edge.
And I suspect the machine will need to heat the edge prior to bending.
I know there are manufacturers that use this technique and these machine exist but I cannot find a vendor.
