Percentage fiber elongation in Div 2 as per table 6.1 A
Guys,
How are you all, I was yesterday designing a vessel having a transition cone, and while I was checking the calculation I came to know that compress takes the value of t in the fiber elongation calculations for cones and transition other than nominal thickness considered i am attaching the calculation with this query, it takes 93.96 mm instead of 90 mm how it has added 3.96 mm to the calculations
Syed Zain Ali
Syed Zain Ali
