Heat pump in pharmaceutical industries
what are the probable applications of heat pumps in pharmaceutical industries??? which all possible processes hot water or hewat requirements will be there in pharmaceutical industries and where heat pump can be suggested
RE: Heat pump in pharmaceutical industries
if there is large cooling need, and you can find utilization place for waste heat on low temperature level, than heat pumps can be very feasible.
