Has Anybody Used This Supafix Stuff?
Hi Guys,
We use JB Weld as our adhesive of choice but we have some work which requires smoothing and taking paint. I saw this on Facebook but have no idea what its like.
Has any body used it or anything similar?
How strong is it?
http://youtu.be/uoLUSM9zdkA
Cheers,
How strong is it?
Cheers,
RE: Has Anybody Used This Supafix Stuff?
B.E.
You are judged not by what you know, but by what you can do.
We fabricate a lot of I beam and drill with magdrills. When we have a mis drill we patch it so that it is unable to be seen when painted over and re drill in a different location.
At the moment we use JB Weld which works but takes a while to set. I saw the video and thought we may be able to tape over the hole set it, sand it, run a layer of paint down the beam and get it shipped out a little faster!
Can you elaborate on the material of these I-beams?
B.E.
