Normalized Mode Shapes
I am working on a spatial vibration project in which I need to extract the resultant normalized mode shapes in vector form. (e.g for a system with 6 D.O.F a eigenvector with 6 components.) Is there any option in ANSYS to extract the mode shapes in such format?
RE: Normalized Mode Shapes
The normal behaviour of a modal analysis in Ansys is to normalize the results to the mass matrix. So, your displacements are the the eigenvectors. Check this thread on xansys.org:
http://www.xansys.org/forum/viewtopic.php?p=48490&...
HTH
/PB
While specifying your modal analysis options by MODOPT command you must enter Nrmkey equal ON.
MODOPT, Method, NMODE, FREQB, FREQE, PRMODE, Nrmkey, , Cekey
I hoe it helps you.
