Bending size limits
Bending size limits
Good night everyone,
I'm currently working on a project for which I need to create complex forms through bending plate.
I'm not sure if it's possible to use bending to make the following shape, so please advice me.
First image is the sketch with dimensions, second image is the solid version and how it's supposed to look like.
Diana de Bastos
Diana de Bastos
RE: Bending size limits
I doubt you will achieve such a bend its too narrow and too deep, also you cannot obtain sharp corners on the bends as shown in you're sketch.
Depending on the length fold a fabrication shop might be able to swage the ends over similar to what your sketch shows.
I would contact some local fabrication firms and see what they have to say.
If your dimensions are in mm, that's sheet.
In neither case can you achieve sharp edged bends.
In a ductile material, you can achieve an
inside radius around 0.5 times the material thickness. (*)
The outside radius will correspond, in the sense that the
material thickness will not decrease substantially.
See any text on sheet metal fabrication for further instruction.
(*) In a very ductile sheet material, like 18 gage mild steel, you can achieve
an inside bend radius around .005", but it's very hard
on the tools and on the press.
Mike Halloran
Pembroke Pines, FL, USA
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Run through the sheet metal tutorials and see how easy it can be.
Mike Halloran
