Arial text printing hollow
I use an Epson 1270 and the Arial text I use on my drawings has started to print hollow ie: outline.  Where do I look to alter this setting?
RE: Arial text printing hollow
Hey Nob,
Have you checked if the 'text fill' box if checked before you print? The box can be seen when you type 'PLOT' command in ACAD 14.
Hope it helps
Daniel
if you are using acad 2000, type in TEXTFILL, @ the command line prompt then 1
Juice
Also, check any of your hide settings for printing viewports as hidden. MVIEW has a "hide" option, and the PLOT command has a check box for plotting hidden views. These can result in hollow text and arrowheads.
Good Luck
Hi There
With regards to your arial font printing hollow, was'nt there a known bug with the Arial font in 2000, sometime printing hollow, double size, half size or sometime not at all???
