How to format the texts belonging to the titleblock
i'm trying to force a macro to set up desired font for a titleblock but seems like it doesn't work.
here's the code (changing font setting doesn't work in this macro)
Sub CATFormatTBText(textName As String, anchorPosition As String, fontSize)
'How to format the texts belonging to the titleblock
Text.Name = textName
Text.SetFontName 0, 0, "Century Gothic (TrueType)"
call Text.SetFontName ( 0, 0, "Century Gothic (TrueType)")
Text.AnchorPosition = anchorPosition
Text.SetFontSize 0, 0, fontSize '* A4TextFmt
End Sub
this works with another macros but with attached macro this code doesn't work.
what's the problem? two different titleblocks created from the same master macro but in one case i can control font settings through the
macro in other case i cant.
End Sub
RE: How to format the texts belonging to the titleblock
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
in macro when i run titleblock it takes font setting from standard.
