woodwork shearwall reports
I'm having a hard time configuring the Woodwork Shearwall result report not to print the large WOODWORK label at the top. I'll take a work around solution if that's the only way. Trying to make the calculations package a little more uniform.
RE: woodwork shearwall reports
None that I know of. It's very typical for 3rd party programs to have their own header. It helps the plan checker know that the engineer is using a program instead of their own calculations and gives it some trust. Without the header, a plan checker might ask what the program is, how it works, and to submit an example to prove it.
