Searching for a code if any (vessel)
Hey guys...I have a vessel that contains a solution of a flammable liquid diluited in water (ammonia like) at atmospheric temperature and pressure. The vessel capacity is less than 0.5m3. The vessel doesn't have a nitrogen blanket. Vapor outlet is connected to a hood w/ extractor. Is possible not to apply ASME VIII Div 1? Is any other code or normative that I could apply? (ANSI, API, BS, etc)
Thanks in advance!
RE: Searching for a code if any (vessel)
PD: vessel material is stainless steel. Plastic is not allowed.
What does the local Jurisdiction or regulatory body require where this object is installed regarding exemptions for pressure vessels based on pressure, contents or size?
metengr, gonna take a look
Note that some jurisdictions don't have vessel code requirements.
Whats the location where the vessel is installed/used?
Come on guys, providing this is truly designed as an Atmospheric vessel, its not a pressure vessel, but a tank. ASME VIII AFAIK is not designed for anything under 15 psig, but even tank design allows some design pressure.
You probably just need to design to a local standard or perhaps look at this thread http://www.eng-tips.com/viewthread.cfm?qid=377874 for some ides.
At 0.5 m3 this is a small horizontal cylindrical tank.
Supersonic - Check what the design pressure / MAWP is for this tank. Anything below 15 psig should mean it's a tank not a pressure vessel - the hint is in the name....
Tank will be Located in Argentina, South America. Local jurisdiction don't have vessel code requirements.
I have a mechanical engineer friend of mine that suggested to use ASME IX (only for the welds).
Design pressure is 3 bar. An inlet connection receives liquid from the recirculation of a positive displacement pump.
PD: At this time I don't know if it is a Tank or a vessel :P
Ok, that's new information. First see if you can actually re-rate the design pressure. If the vent is atmospheric and there's no way to seal it off, having a design pressure of 3 barg is really overkill and will cost you a lot more than an "atmospheric" tank. A bit of work on the process side will more than save the money and time.
If you don't want to go down that route then you are really looking at a Pressure Vessel code of some sort. You might have got away with a design pressure of less than 1 barg, but 3 is too high.
Good. I understand that is possible to re-rate if the vent outlet is big enough compared to the pump flow.
At 3 bar, it is a pressure vessel. Falls under ASME VIII.
At [up to] 1 bar, it is a 'tank' and you can use API-620, UL-142, API-12F [very low psi]
I just found the PIP VESLP001 Low-Pressure, Welded Vessel Specification really useful as a guideline.
It states what Duwe6 said in the previous post.
