Question about Amplitudes and Mapped Fields.
Hi there,
I need to use Amplitudes (I'm using Tabular type) and Mapped Fields in a simulation that I'm working on.
The problem is that I don't know exactly how the field 'Amplitude' in the 'Edit Amplitude' Window works. The same happen with the 'Field Value' in the 'Create Mapped Field' window. I don't know if they are multipliers, percentages, or the value that I want it self.
Here are the documentation, but I can't understand exactly what that means:
Amplitude: http://www.maths.cam.ac.uk/computing/software/abaq...
Mapped Field: http://www.maths.cam.ac.uk/computing/software/abaq...
Thanks in advice,
Regards.
Thanks in advice,
Regards.
