Old Model with WAVE Linked Body
Updated to NX 8.5 a few months back. Have a very old model with WAVE Linked Body in it. I don't know the version which the original model was created. It has since been saved in 8.5. The "hide original" option is not available when using Edit Parameters or Edit With Rollback.
This probably should have been a Promote Body, since it was a component of an assembly that was machined (hole patterns added) after assembly.
Is there a way to update the WAVE link or change to Promote Body without having to redefine the hundreds of holes that are added? We have a very confusing assembly model where you can see the original body without holes overlaid the machined body at the assemebly level. Creating havoc with weight management and our suppliers.
RE: Old Model with WAVE Linked Body
NX7.5 + TC8.3
Painful part was fixing all the holes and features that lost their references during the update.
wacio- I didn't know about replacement assistant. Where is it? I could not find it using command finder.
NX7.5 + TC8.3
