Problem with the use of vector elements in Given-Find block
Hello all,
I have such a problem - I want to use vector elements variables, ie. x[1 instead of x.1 in the Given-Find block, but I can not, because I get "Something is wrong with the solve block used to define this function" error. Anybody know why I can not use vector elements variables? I have also noticed that ie. if I write x[1 = 1 and in the next line x[1 = 2 Mathcad redefines previously defined variable, but there is no green underline and no "This expression redefines a previously defined variable" inscription, as it is when typing x.1 = 1 and then x.1 = 2. I use MC15.
Thanks in advance for help.
Pederator
RE: Problem with the use of vector elements in Given-Find block
It just doesn't. You should define the solve block with a single variable and assign the find to a function, ala,
fcn(x) := find(y) and then pass your vector to x
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Can you please attach an example or explain more detailed? I used to assign Find to a column vector, ie. (origin 1)
|x[1|
|x[2|:=Find(x.1,x.2,x.3)
|x[3|
Thanks for help.
Because i ususally find elements that are not started from 1, and also these are various variables, ie. m.4, m.7, m.8, m.9, h.7, h.9 etc. Above was just an example.
