Cartridge heater system
I am working on a rapid heating device to eliminate the need to preheat in an oven. I have the thermal aspect of the design figured out, but I am unsure how to go about electrical component selection.
My understanding is that I will need a power supply to supply 12 250W catridge heaters, some temperature control system and relays for turning the heaters on and off. I could also just eliminate the temp controller and have a on/off switch to turn the heater on until the correct temp is reached. Does anyone know of any resource that would help put together such a system? It seems like it is more complicated than just hooking up a correctly sized power supply to the cartridge heater with no other components.
Also, this is my first post and am unsure I am in the right place.
RE: Cartridge heater system
Mike Halloran
Pembroke Pines, FL, USA
Most ovens have safeties for over-temperature protection. Electrical fusing for short circuit protection. And a controller to profile and regulate the temperature. Also, some way to physically control the power to the elements, its choice and type is often very important for good life time and reasonable control. Whatever is being heated needs to be understood so the proper configuration can be chosen.
Keith Cress
Dan - Owner
http://www.Hi-TecDesigns.com
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
