Nitric, sulfuric and Hydrochloric mix?
If a there were an acid mixture containing( Nitric, Sulfuric and Hydrochloric) what would the corrosion behavior of the mix be? Oxidizing? Reducing? I don't have any concentrations yet. The obvious thing would be that the acid with the biggest presence would take precedence over the others, is this off base? Would an alloys corrosion resistance to one be affected by the presence of the other acids?
RE: Nitric, sulfuric and Hydrochloric mix?
If it is highly concentrated then there are some option, if not........
What kind of equipment are we talking about?
