silver solder mask
silver solder mask
We need to silver solder some tungsten tiles to some forged carbon steel parts. There are 2 threaded holes in reasonably close to the solder area. Normally we tap the holes after the soldering/brazing operation, as there were reports of distortion of the tapped holes that go thru the brazing oven.
It was suggested that putting setscrews in the hole it may limit the distortion to an acceptable level.
Is there some paste or putty that would keep the brazing from possibly creeping into the thread inter-stitials ?
RE: silver solder mask
http://www.henkelna.com/product-search-1554.htm?no...
Something like: http://www.bradyid.com/bradyid/catalog/siteSearchR... designed as a solder mask. So it should be ok for brazing temps. Maybe.
Mike Halloran
Pembroke Pines, FL, USA
Been told that Milk of Magnesia works
Nitric acid can make Tungsten Carbide non wetting
Free carbon is non -wetting.
Still and all we prefer the pens form Nicobraz.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
I have used the BN trick also. We sprayed the bolts before putting them in place.
Dan Timberlake
