Hoist Beam Design
Hoist Beam Design
Have a 21 ft span, a 1 Ton capacity and is outdoor, supported at each end.
I looked at CMAA 74 but need a more simpler lamgauge or an example.
Any help (sample calc or reference) will be appreciuated.
It has to be an "S" shape
Babak
Babak
RE: Hoist Beam Design
http://www.integritycrane.com/downloads.htm
AISC 7 has formulas for the longitudinal and lateral loading for the hoist.
ASME B30.11 looks like it is construction, installation, operation, inspection, testing,
and maintenance of under hung crane and monorail systems.
per ASME B30.11-2010
"11-2.2.2 (d) If a load test is conducted, the load shall be not less than 100% of the rated load of the crane or monorail
system or more than 125% of the rated load, unless otherwise recommended by the manufacturer or a qualified person."
boo1 is correct that B30.11 is not a design document.
You may want to look at this sheet for a quick check but I'd encourage you to do your own homework as well.
