EHT and galvanised pipe
I have a consultant who advises against using EHT (electric heat tracing) on galvanised pipe for firewater purposes on the ground that the localised heating can deteriorate the internal coating, cause clogging & premature corrosion failure of the pipe.
I am unconvinced that the problem is actually so severe that we have move away from using galv. pipe.
Any feedback ?
Any feedback ?
RE: EHT and galvanised pipe
Can you also ask the consultant for references to his advice? Perhaps he knows a bit more of your piping conditions than you disclosed us in your post.
Cheers,
gr2vessels
appreciate your feedback.
Beyond that, I'm not exactly sure where the consultant may be coming from, other than I believe there is even a school of thought (I believe some disputed by the galvanizers) that there can actually be a reversal of polarity in the galvanic protection at lesser temperatures in some exposures. Again one could find information on this with a good web search and these keywords. All have a good weekend.
