Specify view foe datum plane
I'm in Creo 2. I imported a cylindrical model (.sat) but only
the geometry (feature lines)shows in the isometric view in Creo. There is no
coordinate system, axis or datum planes. I created these items but there is no
other views in the tool bar (top, right, etc). How can i create the views so
that I can select from the tool bar, the top view, and the model will rotate
to the top like it does when parts are first created in Creo?
RE: Specify view foe datum plane
Start a new part using your normal start part, then go to the MODEL tab > Get Data drop down > Import. You should then be able to browse to the file and add it to your part. It will come in as "Import Feature id XXX" (where XXX is the feature id number), but that is probably what you are already seeing since this is a file with no feature history.
The nice thing about importing parts this way is that your part units are automatically set by the start part, not by the units of the file imported or the default units of Creo. Also, any user defined parameters or relations you may have in your start parts are already included.
Thanks a lot for your input. It worked great!
