NXOpen.tag cannot be converted to NXOpen.Face
Dear Forum,
I am using NXOpen function theUfSession.Modl.CreateRevolved(objarray, {"0", "360"}, origin, vect, FeatureSigns.Nullsign, features) to create a revolved sheet body from a line in the xy-plane. Next I want to extract the face of this revolved and pass it into another function to create intersection of curves. How do I cast an NXOpen tag into an NXOpen face?
Thanks in advance.
Thanks in advance.
RE: NXOpen.tag cannot be converted to NXOpen.Face
www.nxjournaling.com
CODE -->
Graham Inchley, Systems Developer, Sandvik Coromant. www.sandvik.com
HP EliteBook 8760w, Win7, 8GB. Developing in: Java | C | C# | KF
Production: NX6.0.5.3 MP5
Testing: NX8.5.3.3 MP4 64bit | NX9.0.2.5
I am using the following function theUfSession.Modl.CreateRevolved(objarray, {"0", "360"}, origin, vect, FeatureSigns.Nullsign, features). The revolved surface is getting created but I am having problems casting the features(0) into a face. I've journaled the activity of taking the revolved sheet body and intersecting it with another sheet body to try and finding the casting.
Here's the snippet from the journal:
Dim bodyFeature1 As Features.BodyFeature = CType(workPart.Features.FindObject("REVOLVED(13)"), Features.BodyFeature)
Dim face5 As Face = CType(bodyFeature1.FindObject("FACE 67700 {(0,0,34) REVOLVED(13)}"), Face)
It might be a bit easier if you create the revolve with a RevolveBuilder; this will give you a reference to the newly created revolve feature without messing about with tags.
theUfSession.Modl.CreateRevolved(objarray, {"0", "180"}, origin, vect, FeatureSigns.Nullsign, features)
Dim featName As String = Nothing
theUfSession.Modl.AskFeatName(features(0), featName)
Dim bodyFeature1 As Features.BodyFeature = CType(workPart.Features.FindObject(featName), Features.BodyFeature)
Dim hoop() As Face = bodyFeature1.GetFaces()
Dim TestIntersect As Features.IntersectionCurve
TestIntersect = Nothing
For iii As Integer = 0 To hoop.Count - 1
Try
TestIntersect = createIntersectionCurves(Airfoil, hoop(iii))
Exit For
Catch ex As Exception
If iii.Equals(hoop.Count - 1) Then
'Throw New Exception("Failed to Find Intersect of Radial Hoop with Airfoil")
Return Nothing
End If
End Try
Next
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Sub Main() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "NXJ journal" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) 'create line to use in revolve feature Dim revolveLine As Line revolveLine = workPart.Curves.CreateLine(New Point3d(0, 25, 0), New Point3d(25, 25, 0)) 'revolve about absolute X vector Dim thePoint As Point = workPart.Points.CreatePoint(New Point3d(0, 0, 0)) Dim theDirection As Direction = workPart.Directions.CreateDirection(thePoint.Coordinates, New Vector3d(1, 0, 0), SmartObject.UpdateOption.WithinModeling) Dim axis1 As Axis axis1 = workPart.Axes.CreateAxis(thePoint, theDirection, SmartObject.UpdateOption.WithinModeling) 'create the revolve builder Dim revolveBuilder1 As Features.RevolveBuilder revolveBuilder1 = workPart.Features.CreateRevolveBuilder(Nothing) revolveBuilder1.Limits.StartExtend.Value.RightHandSide = "0" revolveBuilder1.Limits.EndExtend.Value.RightHandSide = "360" revolveBuilder1.BooleanOperation.Type = GeometricUtilities.BooleanOperation.BooleanType.Create revolveBuilder1.Tolerance = 0.001 revolveBuilder1.FeatureOptions.BodyType = GeometricUtilities.FeatureOptions.BodyStyle.Sheet revolveBuilder1.Axis = axis1 'create section for revolve builder Dim section1 As Section section1 = workPart.Sections.CreateSection(0.00095, 0.001, 0.5) section1.SetAllowedEntityTypes(Section.AllowTypes.OnlyCurves) section1.AllowSelfIntersection(False) Dim curves1(0) As IBaseCurve curves1(0) = revolveLine 'create curve rule Dim curveDumbRule1 As CurveDumbRule curveDumbRule1 = workPart.ScRuleFactory.CreateRuleBaseCurveDumb(curves1) 'create selection intent rule Dim rules1(0) As SelectionIntentRule rules1(0) = curveDumbRule1 Dim nullNXObject As NXObject = Nothing 'add our input line to the section section1.AddToSection(rules1, revolveLine, nullNXObject, nullNXObject, revolveLine.StartPoint, Section.Mode.Create, False) revolveBuilder1.Section = section1 'revolveBuilder1.ParentFeatureInternal = False Dim feature1 As Features.BodyFeature feature1 = revolveBuilder1.CommitFeature() revolveBuilder1.Destroy() 'report the feature faces lw.WriteLine(feature1.GetFeatureName & " contains: " & feature1.GetFaces.Length.ToString & " faces") Dim theFaces() As Face = feature1.GetFaces() For i As Integer = 0 To theFaces.Length - 1 lw.WriteLine(" face " & i.ToString & " color: " & theFaces(i).Color) lw.WriteLine(" face " & i.ToString & " layer: " & theFaces(i).Layer) lw.WriteLine(" face " & i.ToString & " area: " & FaceArea(theFaces(i)).ToString & " square inches") lw.WriteLine("") Next lw.Close() End Sub Function FaceArea(ByVal inputFace As Face) As Double Dim theFaceArea As Double Dim measureFaceBuilder1 As MeasureFaceBuilder measureFaceBuilder1 = workPart.MeasureManager.CreateMeasureFaceBuilder(Nothing) Dim unit1 As Unit = CType(workPart.UnitCollection.FindObject("SquareInch"), Unit) Dim unit2 As Unit = CType(workPart.UnitCollection.FindObject("Inch"), Unit) Dim objects1(0) As IParameterizedSurface Dim measureFaces1 As MeasureFaces Dim added1 As Boolean measureFaceBuilder1.FaceObjects.Clear() added1 = measureFaceBuilder1.FaceObjects.Add(inputFace) objects1(0) = inputFace measureFaces1 = workPart.MeasureManager.NewFaceProperties(unit1, unit2, 0.999, objects1) theFaceArea = measureFaces1.Area measureFaces1.Dispose() measureFaceBuilder1.FaceObjects.Clear() measureFaceBuilder1.Destroy() Return theFaceArea End Function End Modulewww.nxjournaling.com
