NX 7.5 - Assembly Constraints w/ Gray Text?
Good morning, Eng-Tips,
I have run across an assembly file that has some assembly constraints whose text is "grayed-out" in the Dependencies pane of the Assembly Navigator. I've attached an image to clarify (I removed part numbers for confidentiality reasons). I've looked online and through the help file, but I can't figure out what the grayed-out constraints signify. You'll notice in the attached image that one constraint has black text and the other has the gray text I am talking about. Does anyone know what these grayed-out constraints mean?
Thanks!
Thanks!
RE: NX 7.5 - Assembly Constraints w/ Gray Text?
They're blanked out (on screen), it's the same as when you blank a loaded component.
www.jcb.com
NX 8.5 with TC 8.3
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
