TABLES AND ATTRIBUTES
Hi all,
Wanting to know if there is a way to reference the value of a table cell in the attributes?
TO explain more, i have created a template where by it takes the 'name, part number, material & machine' from the master model, i did this by using the 'Attributes template' under utilities (using this formula DB_DWG_TEMPLATE_Machine) this worked perfectly in the title block but it does not seem to update the attributes at all. Is there a way that i can reference the text in the title block to the attribute or even reference the 'attribute template'?
Tried a few other methods (like using dummy file's) but to no avail and now I am completely stumped!
Any help appreciated!
James
James
RE: TABLES AND ATTRIBUTES
Richard
