Color fill a drawing sketch
Hello.
First, sorry my bad english.
Can anybody help me with my problem.
I have a sketch in my draing, and i want to fill it with red color. Is there anyway to do this?
RE: Color fill a drawing sketch
Best regards,
Michaël.
NX7.5.4.4 (NX8.5.3) + TC Unified 8.3
Win 7 64 bit
Best regards,
Michaël.
Win 7 64 bit
When I uncheck monochrome turns all lines to blue.
Is there a way to change the line color to black?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Or...
Edit your view style, on the "visible lines" tab, change the color to black; repeat for "hidden lines" and "smooth edges".
If this is something you will use often, change your template parts and/or customer defaults to the desired colors.
www.nxjournaling.com
Actually this is a much better solution since any new curves will automatically update to black as well. And, as mentioned, if this is going to be your normal style of output, you can preset these colors in Customer Defaults or when you create your templates.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
