Non-Circular flange with Non-Circular Bore
Hello
I need some guidance on how can i Design Non-circular flange with Non-Circular bore Flange. Actually my flange shape is Oblong with major axis and minor axis.
thanks
thanks
RE: Non-Circular flange with Non-Circular Bore
So give us some dimensions.
Major axis I.D=450mm
Minor axis O.D=435mm
Minor axis I.D=350mm
Shape is like circular oblong.
Type of flange is somewhat similar to APP.2 fig 2-4-6a..Design pressure=6bar, Temp=200°C,M.O.C=SA181 Gr 60.
Now, that may be a problem on my end, but your description doesn't make sense.
It's low pressure, low temperature, so it can be fabricated fairly cheaply. Somehow.
Now. Draw it. Inlet and outlet nozzles - seem to be the two above based on OD and ID. Maybe.
Length, end-to-end?
Type of material for transition?
Bolt "circles" at end mating flanges? Bolt diameters and bolt hole diameters? nbr of bolts?
Flange surfaces? flange styles?
or is this a single flange, mated to its partner that is a combination of the two major OD and minor ID's above?
Thanks for your help.
Did you try UG-34?
Cheers,
gr2vessels
My component is not flat head and cover its like STUB END, which is fastened with C-Clamp to cover(which i can design as per UG-34) and it has oblong shape because on matching cover its has two 150 and 80 Dia. glass.
See also http://www.eng-tips.com/viewthread.cfm?qid=4009 and search for "Oval flange design" or "non circular flange design" on this site and elsewhere.
To upload files, look at the bottom of the screen below the text section of the reply section.
You will see "Attachment" as a label, and a paperclip icon. Create (draw, sketch, CAD or scan your file - usually as a jpg or pdf file type) the file, then follow the "clip here to upload your file" instructions.
Thanks to racookpe1978 for your reply but please dont mind that i mean i cant upload because of restriction from my workplace. while i can draw anything if its available in post options.
Thanks to gr2vessels for your reply.
