gas turbine mathematical problems/exercises
would you know of a respected book that would give a number of worked problems/exercises on gas turbines and accessories
thank you
RE: gas turbine mathematical problems/exercises
What kind of problems?
What gas turbine textbooks do you already have?
What textbooks does your company have?
Are you looking at operational problems, or "pure" (theoretical) heat exchange theory and heat engine efficiency theory problems? Or design problems (bearing designs, leakage, fuel systems design, cooling air calculations, heat expansion, creep, sag, foreign object damage, clearances, seals, high temperature metallurgy, fin cooling air methods, fin ceramic coatings and internal air flow, exhaust gas problems and pollution control, instrumentation and sensors and controls?
Yes, I was interested in HORSEPOWER, HEAT RATE, etc.
thank you
