NX 9.. Selection inside/crossing not working
Was using 8.0
Now doesn't seem to work with 9.0 just updated yesterday.
Example: see some data I don't want on my drawing like center lines or something
I use to be able to swipe the top of a line and it would highlight the whole line.
Thanks!!!
RE: NX 9.. Selection inside/crossing not working
The setting is found in Preferences > Selection, or you can include it on your selection toolbar.
www.jcb.com
NX 8.5 with TC 8.3
Thanks, that worked
I was trying to change it under gateway
No problem, I normally leave the drop-down available on selection toolbar so it's there when I need to change it.
www.jcb.com
NX 8.5 with TC 8.3
