Culvert design - estimating post-construction ordinary high water
NYSDOT's scour protection details show stone fill to one ft (0.3 m) over the ordinary high water level. The replacement culvert will be 50% wider than the existing one, which should reduce the OHW elevation.
From Army Corps:
So for design purposes, should I use the existing OHW elevation, knowing I'll be using more stone than absolutely needed? Or pick a reasonably frequent recurrance like the 0.5 or 0.2 storm?
From Army Corps:
Quote (“The term ordinary high water mark means that line on the shore established by the fluctuations of water and indicated by physical characteristics such as a clear, natural line impressed on the bank, shelving, changes in the character of soil, destruction of terrestrial vegetation, the presence of litter and debris, or other appropriate means that consider the characteristics of the surrounding areas.”)
RE: Culvert design - estimating post-construction ordinary high water
for culvert design I would typically use the design water level for the design storm to set the limits of riprap. That is generally higher than a 2 or 5 year storm. Most culverts are designed for at least 10 year or 25 year, sometimes 50 year.
In Georgia we size rip rap aprons for the 25 year storm. I'm sure this varies by state.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
Only if the system is operating under Inlet control.
