Double sided bolt
Double sided bolt
Hei,
could you help me with proper English name for double sided bolts and suppliers for them. Bolt needs to have two opposite threads on each side with a hexagonal shape in the middle that can't be removed.
Or, the name of a part which has innear thread on the leaft side, threaded in left direction, and on the right side a bolt, threaded in a right direction.
Or, both sides to be with inner threads.
Maybe is a variation of a stud, but with different direction threads and with an unmovable nut in the middle.
RE: Double sided bolt
I would call it a stud even with two different threads at each end, I guess you will be providing a drawing to whoever is supplying it?
http://www.midwestcontrol.com/series.php?id=89
It will be a custom made part.
How it's made will depend on the quantities you need, and that in-turn will decide the potential manufacturers.
You will need a drawing.
Thank you all for your responses, guess i'm going to have to make it. :D
It looks like the OP wants one end to be an M6 internal thread, with the other end an M8 external thread. Midwest Control only shows regular double ended studs.
I can't picture this as off any shelf, particularly with the lh/rh thread combination.
boo1, for me to use a hex bar turnbuckle with a stud I would still have to find one of them that has a different size of threads and different rotations. And I would have an unnecessary connection which will cause me a problem. They also have something called step down/up adaptors and they have different thread sizes but not directions.
3DDave, yeah, if they had sizes larger than M6 (I need M8) and a hexagonal shape not the hole, that would be it.
What material?
How accurate/what kind of spec? or tolerance?
There are companies that make these to your dwg, even if not a "named" common part?
