Temporary Retaining Wall using Bunker Blocks
Hello-
We are designing a temporary retaining wall to allow our client to store their product. They are wanting to use, from what they described are "bunker blocks" (image linked below). I am looking to see if anyone has any experience in designing a retaining wall using this kind of material? Any information will greatly be appreciated.
Thank you
Image link: https://www.google.com/search?q=precast+concrete+b...
Thank you
RE: Temporary Retaining Wall using Bunker Blocks
Over more than a small handful of courses, they stop being reasonable as gravity walls because of the quantity required and the necessary space. After that, you need to reinforce the wall somehow. This is typically done using tieback or geotextiles. Neither option is really feasible when your surcharge is a stored product. If you have lots of space, this may not be an issue.
www.PeirceEngineering.com
http://www.eng-tips.com/threadminder.cfm?pid=255
They would basically be a gravity retaining wall. I see them used a lot for gravel and mulch storage.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Was there a standard for the size, shape, strength and features of the "mafia" block?
I never heard of any consensus standard for the blocks the provides for features (joints, shear lugs, etc.).
That is a reason for the gravity wall approach.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
We have done some more research, and found out that RetainPro program using the gabion analysis will work with this type of block situation.
I too have used RetainPro's gabion method for these blocks.
