8-node brick element load vector
Hi friends,
I am trying to calculate 8-node brick element load vecotr. Top face consist from points 1-2-3-4, bottom face from points 5-6-7-8.
When I am calculating self weight (body forces) I am using 8-node brick shape functions (8 shape functions).
When I have a surface load perpendicular to face 1-2-3-4, do I use 4-node plane sheet shape functions ? (4 shape functions) Result of surface load on face 1-2-3-4 are only nodal fprces in nodes 1,2,3, and 4?
How about traction on the 1-2 edge of brick element, do I use only 2-node link element shape functions (2 shape functions)?
Or do I always have to use 8 shape functions for brick element for any type of forces (body, surface, or edge traction)?
How can I solve the problem on the attached picture ?
Thank you for your suggestions!
RE: 8-node brick element load vector
If you are using a reputable FEA program they have all been through a lot of bench marking of all their element types against NAFEMS standards.
If you have a column or a beam or a plate or a potato type structure use the appropriate element type and get going with the loads and constraints. Then try to verify the results..
Shape functions etc. are all grad school or PhD topics. Unless you want to go into research I'd say focus on the application.
Again just my personal opinion..
www.stressebook.com
Stressing Stresslessly!
I also often do it like this - I analyse my problem in ceftified FEA soft, and then tune my theory. But this time I cant move from a place, no matter the results :) So I am looking for somebody experienced to discuss my problem.
But still - thank you.
